Port-channel algorithm on 7200 or GSR
Feb 9th, 2010
Please help me to find out which is the algorithm used by 7200 or GSR on (GE) port-channel configuration!
GSR would be the P router, 7200 is the PE.
Topologie:
CE --- PE (7600) === P (GSR) === PE (7200) --- CE
7600 works well, but GSR and 7200 using only one link of two. This is an MPLS^VPN environment.
I used same source and different dst IP addresses during test.
Thank you for your help!
Gabor
Giuseppe Larosa Tue, 02/09/2010 - 12:20
Hello Gabor,
C7200 and GSR are routers not multilayer switches I would suggest you to remove port-channel configuration and to use the two links as two parallel L3 links.
Hope to help
Giuseppe
