WS-X6066-SLB-K9-S Redundancy
Feb 9th, 2010
Hello;
In our topology we try to use two csm-s  module on different 6509 chasis. In our network we use hsrp  configuration, so csm-s module's running as active-passive.
According  to cisco documents, we couldnt be able to pass clients vlan on load  balancer configuration between two chasis trunks port. Also according to  same documents we configured fault tolerance vlan on 6500 switches.
But  for server ethernet redundancy we configured teaming ethernet interface  on the servers and finalized on different 6500 switches. So when the  ethernet port on active backbone is plug off, because of trunk port vlan  restiriction , we couldnt reach servers behind load balancer.
We  want to know if there is another solution for this csm-s configuration.  Could we use active-active envionment ?
Must we  exclude client vlans on load balancer configuration on trunks port  between two 6500 chasis ?
Best regards
Umut.
