AIM2-CUE Error Language package install
Feb 9th, 2010
Hi experts,
I am having the following problem:
Router 2851 with 124.24T IOS with CME 7.1.1
Modules: AIM2-CUE ver. 7.1.2
I need to install the Portuguese language pack and the command that i am using in the CUE CLI is:
software install add url ftp://ftpserveripaddres/cue-vm-pt_PT-langpack.nmx.7.1.2.prt1 username cisco password cisco
The result is this:
WARNING:: This command will install the necessary software to
WARNING:: complete a clean install.  It is recommended that a backup be done
WARNING:: before installing software.
Would you like to continue?[confirm]
Downloading ftp cue-vm-pt_PT-langpack.nmx.7.1.2.prt1
Bytes downloaded :  37419891
Validating package signature ... done
ERROR: Invalid package. Please verify if this is a valid package file.
Can you please help me?
Best regards,
Nuno
Paolo Bevilacqua Tue, 02/09/2010 - 07:00
Cannot not install the language .prt file directly like that.
Instead, install upgrade the language package .pkg, from there you will have a menu selection, and choose from there.
