Firewall FTP Problem
Feb 9th, 2010
i have firewall ASA 8.0(4). My FTP server is located in DMZ side and one FTP server is located on inside network.  DMZ Inside
From DMZ I can do the FTP and everything but from inside I am not able to do the FTP to DMZ server. Though Ping and remote
desktop i can do.
Below is the configuration of my firewall.
interface GigabitEthernet0/1
mac-address 000c.f542.4abc standby 020c.f542.4abc
nameif inside
security-level 100
ip address standby
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface GigabitEthernet0/3.1
mac-address 000c.f342.4abc standby 020c.f342.4abc
nameif serverdmz
security-level 90
ip address standby
access-list acl-in extended permit ip host any
static (inside,serverdmz) netmask
access-list acl-serverdmz extended permit ip host any
access-list aclnat_serverdmz extended permit ip any
nat (inside) 2 access-list aclnat_cards
nat (inside) 3 access-list aclnat_serverdmz
nat (inside) 1
nat (serverdmz) 1
global (partners) 1 netmask
global (serverdmz) 1
global (serverdmz) 3 interface
global (cardsdmz) 2 interface
ENOCDC-FW01/Rack1# show conn address
1933 in use, 15723 most used
TCP serverdmz inside, idle 0:00:31, bytes 1798427, flags UIO
from dmz to inside everything is working fine but from inside I am not able to do the FTP on DMZ server. though the FTP server is working fine locally.
Please help me out how to find a solution for this.
sachinraja Tue, 02/09/2010 - 08:52
Hi Wasim
Is the FTP server in DMZ ? Are you accessing it from or any other PC from the inside network ? I see the ACL
This will allow only traffic from to go from inside interface.. If you are trying to FTP from any other IP you might need to add another ACL similar to the one below
access-list acl-in extended permit tcp host eq ftp
or you can probably allow ip from to (for testing)
You might also need to build a static entry for the FTP server to inside , just as the way you did for the inside FTP server
static (serverdmz,inside) netmask
or you can also define a nat 0 for traffic going from inside network to the DMZ segment
nat (inside) 0 access-list 111
access-list 111 permit ip
You would be able to access the FTP server once you make these changes
Hope this helps.. all the best
