HUM
Answered Question
Feb 9th, 2010
I have installed HUM evalauation it installed sucessfully i have seen in the common services but i can't see HUM in LMS portal page.
Correct Answer by Joe Clarke about 7 years 2 weeks ago
Make sure you are looking at the LMS portal and not My Portal or CiscoWorks Portal.  You should see a HUM view tab.  Note, depending on the screen resolution, you may have to click on an arrow icon to view other portal views.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 02/09/2010 - 10:23
