What am I missing
safety2008
Level 4
Level 4
Hello all,
Below i have attached 2 scripts. i had to change a recording on it. the orig is v6, i changed the recording and it would not work. sytem error message, try the debug aand i get a triggering contact error. but if you look at the one that works v8. they, at least to me, are identical..wth did i blow away in the v6 script that broke it?
thanks in advance
jyoung
What recording did you change?
