02-09-2010 07:08 AM
Hello to everyone.
I am not an experienced Cisco Engineer and have been handed several 837/857/877 routers located at remote small sites pointing to a PIX at our HQ.
I inherited the config from a previous company and have left it "as is" by just altering the ISP details and IP Address ranges as required, didnt change the config as it seemed to work.
I reused an 857 which was working fine and altered only the ISP details. The router connects to the internet but fails to automatically bring the VPN up.
If a PC is connected and picks up an IP Address via DHCP the FastEthernet port lights and the VPN comes up a couple of seconds after. If the PC is removed the VPN stays up for a random time then drops. Any help would be greatly appreciated as I am at a loss where to go. The config seems to work at 4 sites but not this one. I have tried an 877 and it displays the same symptoms. Below is the current config with some details xxx out.
Dont be too harsh on me as I am a baby CCNA!!
Current configuration : 4809 bytes
version 12.4
no service pad
service password-encryption
hostname xxxxxxx
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable password 7 08114D5D1A0E0A05165A
aaa new-model
aaa session-id common
resource policy
no ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 10.230.60.1 10.230.60.49
ip dhcp excluded-address 10.230.60.151 10.230.63.254
ip dhcp pool xxxxxxx
import all
network 10.230.60.0 255.255.252.0
domain-name xxxxx.org.uk
dns-server 10.230.12.2 10.230.12.1
default-router 10.230.63.254
lease 8
ip cef
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
ip inspect name myfw udp timeout 15
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name xxxxxx.org.uk
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-636675557
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-636675557
revocation-check none
rsakeypair TP-self-signed-636675557
username xxxxxx privilege 15 password 7 xxxxxxxxxxxxxxxx
username xxxxxxx privilege 15 password 7 xxxxxxxxxxxxxxxxx
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
hash md5
group 2
crypto isakmp key NSHS4T address xxxxxxxx
crypto ipsec transform-set xxxxx esp-des esp-md5-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel toxxxxxxxx
set peer xxxxxxxx
set transform-set NSHVPN
match address 100
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
hold-queue 100 out
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description xxxxx_Network
ip address 10.230.63.254 255.255.252.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
hold-queue 100 out
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxx@xxxxx
ppp chap password 7 xxxxxxxxx
ppp pap sent-username xxxx@xxxx password 7 xxxxxxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
access-list 23 remark SDM_ACL Category=17
access-list 23 permit 10.230.60.0 0.0.3.255
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.230.60.0 0.0.3.255 10.230.0.0 0.0.255.255
access-list 100 permit ip 10.230.60.0 0.0.3.255 10.254.0.0 0.0.255.255
access-list 100 permit ip 10.230.60.0 0.0.3.255 10.39.0.0 0.0.255.255
access-list 102 remark SDM_ACL Category=18
access-list 102 deny ip 10.230.60.0 0.0.3.255 10.39.0.0 0.0.255.255
access-list 102 deny ip 10.230.60.0 0.0.3.255 10.254.0.0 0.0.255.255
access-list 102 remark IPSec Rule
access-list 102 deny ip 10.230.60.0 0.0.3.255 10.230.0.0 0.0.255.255
access-list 102 permit ip 10.230.60.0 0.0.3.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 102
control-plane
banner login ^C
Authorized Access Only
Disconnect IMMEDIATELY If You Are Not An Authorized User
^C
line con 0
logging synchronous
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
transport output ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
ntp clock-period 17176092
ntp server 64.15.175.5 source Dialer1 prefer
ntp server 10.230.12.2 source ATM0
end
02-09-2010 09:12 AM
The tunnel comes up once some interesting traffic is passed to it.
In order to have tunnels initiated even when there is no user traffic destined for the tunnel, I normally set up an ip sla monitor to send a ping down the tunnel, using a source address that matches the interesting traffic ACL.
conf t
ip sla monitor 1
type echo protocol ipIcmpEcho source-ipaddr 10.230.63.254 >
frequency 120
ip sla monitor schedule 1 life forever start-time now
02-09-2010 10:14 AM
Try enabling ike keepalive at both ends..that should help to keep both peers active if no traffic is going through the tunnel, see link bellow.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#solution07
For IOS
router(config)#crypto isakmp keepalive 15
For PIX 6.x
pix(config)#isakmp keepalive 15
