Outgoing Number Translation
Answered Question
Feb 9th, 2010
I am trying to translate all outgoing calls in a remote office to one number and keep getting an error in the translation pattern (numbers changed to protect the dumb).
Router1(config-translate)#rule 1  /9.*/ /5555551234/
Incorrect format for Translation Match Pattern
        regular expression must be of the form  ^(\^)?(\+)?([0-9,A-F.*%?#]+)$
Invalid match pattern string input /9.*/
Am I going about this wrong?
Correct Answer by markbatts about 7 years 1 week ago
Just checking that you need to use a "voice translation-rule" rather than the standard "translation-rule" to make this work.
cheers
mark
Overall Rating: 5 (1 ratings)
robloeber Tue, 02/09/2010 - 07:19
Unfortunately that did not work either.
Router1(config-translate)#rule 1  /9.\*/ /5555551234/
Invalid match pattern string input /9.\*/
Correct Answer
markbatts Tue, 02/09/2010 - 07:47
cheers
mark
robloeber Tue, 02/09/2010 - 07:51
Mr. Mark Batts you sir are the winner!
*sigh*
All is well now.  Thanks!
CHRIS CHARLEBOIS Tue, 02/09/2010 - 07:47
Perhaps this is a silly question, but why not let the Dial-Peer strip off that digit?  A pots dial-peer will strip off the digits used to match by default.  What does your dial-peer look like?
