Discovering the pvc2300
Answered Question
Feb 9th, 2010
  • Bronze, 100 points or more
Hi all,
Is there another document that will help me settup the pvc2300. My current doc is smart_setup-guide_survellance, It says that I should be able to plug in and have discovered and given an ip address dhcp. This isn't working for me. I've reset it a couple times. It worked a while ago for me back when I was on 7.1.3. Now I'm at 8.0.0 on a UC540. Any tips on what I can do here?
Stephanie
Correct Answer by Marcos Hernandez about 7 years 5 months ago
I meant Desktop. Not Access. Sorry. Did you try the factory reset? Could it be the camera went bad?
Overall Rating: 5 (1 ratings)
Marcos Hernandez Tue, 02/09/2010 - 09:28
  • Blue, 1500 points or more
Stephanie,
What version of the PVC firmware are you using? Can you see if the camera got an IP from the DHCP server ("show ip dhcp binding")
Marcos
SHeidemann Tue, 02/09/2010 - 09:41
Hi Marcos,
No it is not recieving an ip address, so I'm not really sure how to access it to get it to the latest firmware.
Stephanie
Marcos Hernandez Tue, 02/09/2010 - 09:44
Try changing the smartport role of the switchport to "access". Also, try to factory reset the camera.
SHeidemann Tue, 02/09/2010 - 09:50
My options for Roles are Desktop, IP Phone+Desktop, Switch, Router, Access Point, and none. I tried Access Point, and reset it, still no dhcp bind.
Stephanie
Correct Answer
Marcos Hernandez Tue, 02/09/2010 - 09:51
SHeidemann Tue, 02/09/2010 - 10:01
Nope that did it, I have an ip address now...and I can access the web interface. I thought I had tried that but I think I changed it to the data vlan. Switching it to desktop and keeping it at voice vlan gave me both a voice and data ip address.
Thank you Marcos
Stephanie
Marcos Hernandez Tue, 02/09/2010 - 10:04
Hmm, I do not understand what you mean by "keeping it at voice vlan"?
SHeidemann Tue, 02/09/2010 - 10:24
When you select modify smartport settings you choose the device type and you select the access vlan either voice or default, if I had any others configured I'm sure they would be an option from the drop down menu as well.
Stephanie
Marcos Hernandez Tue, 02/09/2010 - 11:03
So you selected Voice as your access VLAN and that made it work? What IP did the camera grab?
SHeidemann Tue, 02/09/2010 - 11:10
It recieved 10.1.1.17 and 192.168.10.11. I could not access the web interface with the 192 address but I can via the 10.1.1.17. I started to follow the directions of the doc and changed it's IP to 10.1.1.9 static, now I have to use that address to get to the gui, but funny thing is my dhcp bindings are still showing the 2 mentioned addresses not the static configured. I hope I'm doing this right by following this guide. Maybe there is another one I should be following because I did just update it and it seems the directions might be a bit different as they are not exact to my options in the gui. Do you know of a recommended guide to begin configuration? I am shooting for video via the SPA525g, should I just recieve conectivity and begin with that guide.
Thanks for the advice
Stephanie
SHeidemann Tue, 02/09/2010 - 12:36
Never mind, the camera ie is pretty intuitive, and your instructions per par!
Thank You,
That was fun!
Stephanie
SHeidemann Tue, 02/09/2010 - 09:43
Should the smartport setting be phone+Desktop, accessing the voice vlan?
Stephanie
