SIP Proxy Licence to be Installed on ASA
Feb 9th, 2010
SIP Proxy Licence to be Installed on ASA. Is there any doco on how to go about installing this licence...
Must admit have not come across this before.
sachinraja Tue, 02/09/2010 - 09:54
Hi Ajaz
were you able to use the "activation-key" command on the ASA ? this is the way we normally upgrade any feature licenses.. not sure about SIP though.. With your PAK key, you can obtain the license key from the URL once you receive your activation key, you can use this:
hostname(config)# activation-key xxxxxxx
hostname(config)# reload
if you have an ASA failover, you might need to do the same procedure to the second firewall, but you might need to first disable failover, and re-enable it after upgrading the license.
Hope this helps.. all the best
