Disable CDP on UC500 WAN port
Feb 9th, 2010
How can I disable CDP on my WAN port. Preferably CCA.
Marcos Hernandez Tue, 02/09/2010 - 09:49
There is no way to do this in CCA. You will need CLI:
UC500#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UC500(config)#int fast 0/0
UC500(config-if)#no cdp enable
John Platts Tue, 02/09/2010 - 10:04
Remember that CDP should only be disabled on your UC500 WAN port if the WAN port is not connected to a SR520, SA520, or SA540. If your WAN port is connected to a SR520, SA520, or SA540, CDP needs to be enabled on the UC500 WAN port for CCA to work properly.
