CM 5.2.1 upgrade
Feb 9th, 2010
Tride to do the 5.2.1 upgrade tonight. Had shut down all services and ran the update.
But it failed with Services still locked.
Canclelled the upgrade but the logs do not show the files which are locked.
Has any one experienced a similar issue.
Joe Clarke Tue, 02/09/2010 - 11:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Typically to make sure the upgrade is successful, I recommend customers set the Daemon Manager, TFTP, RSH, and syslog services to Manual, then reboot.  The install should succeed at that point.  If not, download Process Explorer from http://sysinternals.com, and use it to find files under NMSROOT which are still in use.  Kill the processes using those files, and the install should succeed.
