Lab suggestions
Answered Question
Does anyone know of a good list of lab excercises? I have only one router right now waiting for other equiptment. I have done VLAN
s and Etherchannel many times. What else is important that can be done with 4 switches and 1 router? (For practice for real world)?
Correct Answer by Leo Laohoo about 7 years 3 months ago
Thanks for the rating.
QoS, VACL, rate limiting.
Correct Answer by Ganesh Hariharan about 7 years 3 months ago
With one router and two switches you can try with PBR configuration testing in router by create loopback address and failover of links when you have two links terminating in single router.
with two switches that depends if you have l2 or l3 if l2 then ether channel ,vtp and switch port security command can be achibved.If the switch is l3 then check the configuration of redundacy protocol like hsrp,vrrp or gslb.
Hope to help
If helpful do rate the post
Ganesh.H
Overall Rating: 5 (3 ratings)
Correct Answer
Ganesh Hariharan Tue, 02/09/2010 - 23:39
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to help
Ganesh.H
Correct Answer
Leo Laohoo Tue, 02/09/2010 - 23:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Correct Answer
Leo Laohoo Wed, 02/10/2010 - 00:25
  • Hall of Fame,
    2017 LAN, Wireless
