pix 515e natting to inside host
Answered Question
Feb 9th, 2010
i want to nat public ip to a host on local network.
i want to give http(web) access to this host from outside.
can i do this from ASDM?
Correct Answer by JORGE RODRIGUEZ about 7 years 2 weeks ago
Sure you can do it in asdm that's why is there for ,  try to get use to  doing in it through pix  command line .
Assume server IP is  10.10.10.1 and Public IP 20.20.20.1 , for web access default HTTP port is  tcp  port  80
pix515>
pix515>enable
pix515#config t
pix515(config)#
static (inside,outside)   netmask 255.255.255.255
that is:
pix515(config)#static (inside,outside)  20.20.20.1 10.10.10.1  netmask 255.255.255.255
then inbound access rule
access-list  extended permit tcp any host eq
that is :
pix515(config)#access-list  outside_access_in extended permit tcp any host 20.20.20.1 eq 80
I have not seen ASDM example  ,  you still could use  link bellow  as reference
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080862017.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 02/09/2010 - 12:54
pix515>
pix515>enable
pix515#config t
pix515(config)#
that is:
that is :
