02-09-2010 02:12 PM
I'm having a problem pinging between remote sites. Right now the crypto and no nat ACL's for the different sites just affect traffic between the remote site and the main site. I tryed adding routes, adding the other subnets to the crypto and No Nat ACL's at the remote sites... nothing has worked. Any ideas?
Main Site:
192.168.100.0 - Call Manager / Phone VLAN
192.168.1.0/24 - Data VLAN
Site 1:
192.168.70.0/24 - Phone VLAN
192.168.4.0/24 - Data VLAN
Site 2:
192.168.80.0/24 - Phone VLAN
192.168.3.0/24 - Data VLAN
Main Router
Extended IP access list ACL5
10 permit ip 192.168.1.0 0.0.0.255 192.168.70.0 0.0.0.255
20 permit ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
30 permit ip 192.168.100.0 0.0.0.255 192.168.4.0 0.0.0.255
40 permit ip 192.168.100.0 0.0.0.255 192.168.70.0 0.0.0.255 )
50 permit ip 10.255.255.0 0.0.0.255 192.168.70.0 0.0.0.255
Extended IP access list ACL6
10 permit ip 192.168.1.0 0.0.0.255 192.168.80.0 0.0.0.255
20 permit ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
30 permit ip 192.168.100.0 0.0.0.255 192.168.3.0 0.0.0.255
40 permit ip 192.168.100.0 0.0.0.255 192.168.80.0 0.0.0.255
Extended IP access list NO-NAT
10 deny ip 192.168.2.0 0.0.0.255 192.168.70.0 0.0.0.255
20 deny ip 192.168.200.0 0.0.0.255 192.168.4.0 0.0.0.255
30 deny ip 192.168.2.0 0.0.0.255 192.168.80.0 0.0.0.255
40 deny ip 192.168.200.0 0.0.0.255 192.168.3.0 0.0.0.255
320 permit ip 192.168.1.0 0.0.0.255 any
330 permit ip 192.168.100.0 0.0.0.255 any
Site 1:
ip access-list extended ACL5
permit ip 192.168.70.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.4.0 0.0.0.255 192.168.100.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 192.168.100.0 0.0.0.255
permit ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 10.255.255.0 0.0.0.255
ip access-list extended NO-NAT
deny ip 192.168.70.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.4.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 192.168.70.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.70.0 0.0.0.255 10.255.255.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 any
permit ip 192.168.4.0 0.0.0.255 any
Site 2:
ip access-list extended ACL6
permit ip 192.168.80.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.100.0 0.0.0.255
permit ip 192.168.80.0 0.0.0.255 192.168.100.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.80.0 0.0.0.255 10.255.255.0 0.0.0.255
deny ip 192.168.80.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.3.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 192.168.80.0 0.0.0.255 192.168.100.0 0.0.0.255
deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.80.0 0.0.0.255 10.255.255.0 0.0.0.255
permit ip 192.168.80.0 0.0.0.255 any
permit ip 192.168.3.0 0.0.0.255 any
What do I need to do so these two sites can ping each other? I've looked through the forums but cant seem to find anybody with a similar problem that received a definitive answer.
Thanks in advance!
Solved! Go to Solution.
02-09-2010 02:40 PM
Hi there, I am assuming you need site 1 and site 2 to reach each other via the Main site right? if this is the case then you need to define add the following lines to your crypto ACLs:
Main Router
permit ip 192.168.80.0 0.0.0.255 192.168.70.0 0.0.0.255
permit ip 192.168.80.0 0.0.0.255 192.168.4.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.70.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.4.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 192.168.80.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 192.168.3.0 0.0.0.255
permit ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
permit ip 192.168.4.0 0.0.0.255 192.168.80.0 0.0.0.255
Make sure you add these lines before the last permits
deny ip 192.168.80.0 0.0.0.255 192.168.70.0 0.0.0.255
deny ip 192.168.80.0 0.0.0.255 192.168.4.0 0.0.0.255
deny ip 192.168.3.0 0.0.0.255 192.168.70.0 0.0.0.255
deny ip 192.168.3.0 0.0.0.255 192.168.4.0 0.0.0.255
deny ip 192.168.70.0 0.0.0.255 192.168.80.0 0.0.0.255
deny ip 192.168.4.0 0.0.0.255 192.168.80.0 0.0.0.255
deny ip 192.168.70.0 0.0.0.255 192.168.3.0 0.0.0.255
deny ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
Site 1:
Make sure those lines are added before the last permits
Site 2:
As well make sure these lines are added before the last permits
So pretty much you are telling your routers with these definitions that the remote sites (sites 1 and 2) are gonna be reached via the main one.
Let me know if this is what you need.
02-09-2010 02:40 PM
Main Router
Site 1:
Site 2:
02-10-2010 07:30 AM
That worked perfectly. I appreciate your help!
02-10-2010 07:49 AM
Excellent, make sure you mark the question answered and do rate useful posts.
