Basis question on OSPF Area range command
Answered Question
Feb 9th, 2010
Dear friends,
Lets say that we have a topology where A and B are ABR's and send Type 3 LSA's to router C that is OSPF adjacent to them on Area 1.
So, the topology is roughly like this:
   Area 0
A -------->B
   Area 1
A -------->C
   Area 1
B -------->C
Now lets talk about just A and C.
Should area range command on A be used to summarize:
a. Type 3 LSA's advertised by the ABR A to C in another area
(or)
b. Not all Type 3 LSA's but only Routes installed by C that point to A as next hop. In other words, if both A and B are each advertising 10 Type 3 LSA's to C, and C installs only 5 of them pointing to A as next hop, then should A summarize on these 5 routes only or on all the 10 Type 3 LSA's?
Thanks a lot
Gautam
Correct Answer by Edison Ortiz about 7 years 3 months ago
The behavior of area range on ABR A will depend on which area are you summarizing.
If you perform an area 0 range, ABR A will summarize routes from Area 0 into Area 1 - per your example.
If you perform an area 1 range, ABR A will summarize routes from Area 1 into Area 0 - per your example.
Both conditions are irrevelant to the advertising router shown in the RIB as both ABRs have the same OSPF database.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Wed, 02/10/2010 - 07:33
  • Hall of Fame,
    Founding Member
