Authenticating IOS WGB to WLC via EAP-FAST
Feb 9th, 2010
Hi All,
I note that in the WLC v6.0 config guide support for EAP-FAST is listed under the workgroup bridge configuration section.
Has anyone been successfull in getting this working ?  or have a config example ?
I've had limited success on setting up a WGB wto Auth via WPA2-PSK  , but no luck with EAP-FAST.
Documentation for this stuff seems to be a bit light on.
WLCs are 4402's running v6.0 with ACS 4.2 as my auth server.
Leon
peterkuric Thu, 09/23/2010 - 22:31
Use this in your WGB config:
eap profile eapfast
  method fast
dot11 ssid
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
   authentication client username password
   dot1x eap profile eapfast
That should do it.
I've had success using a few different 12.4 IOS versions but not on 12.3(7)JA3
Also works with Dynamic VLAN Assignment from ACS
Vinay Sharma Sun, 09/25/2011 - 10:49
Hello Leon,
Please mark the Question as Answered, if the provided information by Peter is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
