How can I get phone to ring outloud when one of the lines are off hook, UC560
Feb 9th, 2010
I got a UC560.  I have a phone that has 6 lines configured with the same extension, but different ephone-dns of course.  When I go off hook, on let's say line one, when the next call comes in I see the call coming in on my display, but it doesn't ring.  How can I get the phone to ring when I'm off hook?
jestowe Tue, 02/09/2010 - 17:12
Thank you for visiting the Cisco Community.
So you're using 6 lines with the same extension?  Have you thought about multiple extensions using a hunt group to ring all?  Or shared extensions if you have multiple phones with multiple extensions?
Audy Bautista Tue, 02/09/2010 - 18:06
This client came from an enterprise environment, so I had to replicate the settings as much as possible.
So do you know how I can get the phone to ring loudly even when I'm off hook on one of the lines?
Audy Bautista Wed, 02/10/2010 - 06:19
Issue resolved.  Configuring below did the trick, but make sure you don't have "no call-waiting beep" configured, if you do you'll have to no it out:
ephone-dn  18  octo-line
call-waiting ring
or below if the "no call-waiting beep" is configured:
call-waiting beep
call-waiting ring
