CCME Internal Dialing Question
Feb 9th, 2010
First off, thanks in advance for helping out on this.  I know it should be easy but for some reason I cant figure it out.
I have set up a test CCME and everything is working just fine.  I have 2 phones and they are registered and all is well.  What I am trying to do is not make them call each other.  I would like to basically partition them so they can not dial each other.  I know this is easy in CallManager but I am having a difficult time in CCME.  My router is an old 1751-V running CCME 4.0(3).  I have tired ACL's and that only kills the RTP stream and I have also tried COR lists. Anybody have any ideas on how to make Phone 1 not call Phone 2?
I will post my config if needed.
Anthony
Related Content
