VRF Aware IPSec - Third Party Devices as clients
Feb 9th, 2010
Anybody using VRF aware IPSec feature to connect third party devices like FortiGate firewall to a Cisco router? I am trying to make this work but haven't been successful in doing so. The references that I have found so far point to the fact that the VRF aware IPSec is a remote access feature that works when using the Cisco IPSec VPN client.
Configuration of the Cisco router is attached.
Gaurav
Laurent Aubert Wed, 02/10/2010 - 10:51
  • Cisco Employee,
Hi Gaurav,
You need to apply the crypto-map to your WAN interface:
interface FastEthernet4
crypto map ra
Laurent.
gsabharwal@hns.com Wed, 02/10/2010 - 11:01
Hi Laurent,
Thanks for the reply. The configuration on the router has IPSec enabled. It is missing from the configuration that I attached to the post.
Gaurav
