SIP dialing issue -DTMF
Feb 9th, 2010
I am facing some issue with my SIP trunk.
My setup is like CUCM > Router>ITSP link.
I am able to make outgoing call but when after a call i am dialing a pin from my CUCM ip phone which are SCCP phone the digit are not getting passes to the service provider.
My CUCM ver is 7.0
Plz let me know what to look for and also if any configuration example document you have plz share the same.
what all command shall i look for so that we can check what digit are getting dialed in the router.
Any help will be appreciated.
Rupam
paolo bevilacqua Wed, 02/10/2010 - 02:47
  • Hall of Fame,
    Founding Member
Ask you ITSP: do they support DTMF relay ?
rupam_chakra1983 Wed, 02/10/2010 - 04:12
The image that i am runnig on the router is c1841-advsecurityk9-mz.124-3g.bin.
The isp support dtmf relay.
What else can be done
paolo bevilacqua Wed, 02/10/2010 - 04:14
  • Hall of Fame,
    Founding Member
Which type of dtmf-relay do they support ?
rupam_chakra1983 Wed, 02/10/2010 - 04:18
they support dtmf signalling RFC 2833.
Also the call is gettig established but it is not passing those digit.
there is no voice related config in the router.
Also i have configured the same standard RFC2833 in the sip trunk configuration and kept the media termination point enable.
paolo bevilacqua Wed, 02/10/2010 - 04:19
  • Hall of Fame,
    Founding Member
Post router config.
rupam_chakra1983 Wed, 02/10/2010 - 04:36
find teh config i have done.this is the only config in the router
interface FastEthernet0/0
description WAN
ip address 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description Lan
ip address 255.255.248.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip route 0.0.0.0 0.0.0.0
ip nat pool mypool   prefix-length 28
ip nat inside source list 1 pool mypool overload
ip nat inside source static CUCM_pub
ip nat inside source static CUCM_sub
access-list 1 permit
paolo bevilacqua Wed, 02/10/2010 - 04:41
  • Hall of Fame,
    Founding Member
So router is not involved in telephony.
Check CM settings.
rupam_chakra1983 Wed, 02/10/2010 - 05:02
Is in trunk i have enabled media termination point
CUCM has its software MTU registered
dtmf signalling method is rfc 2833 in the sip trunk config.
what else can be checked,
steigja Wed, 02/10/2010 - 10:33
Does the SIP trunk belong to the Media Resource Group List in which the MTP is in?
rupam_chakra1983 Wed, 02/10/2010 - 22:16
Yes
PFA the SDL trace for reference
In SDL trace i can see " FinjectDigitstoMTP=FsubscribetoMTP "
what does it mean
Message was edited by: rupam_chakra1983
