mobile call issue. cellphone not routed
Answered Question
Feb 10th, 2010
hi
here my strange situation
I try to route the call from isdn to my two internal sip server
all seem ok with normal desk phone
but when I try to malke a call from my cellphone I can't reach any internal sip!!
only with the "connection plar xxxxx" comamnd my cellphone call are ok
but in this case I can't choice the sip server
the configuration is quite simple
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
isdn switch-type primary-net5
voice service voip
fax protocol cisco
sip
voice-card 0
dsp services dspfarm
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-16
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
no cdp enable
voice-port 0/1/0:15
cptone IT
dial-peer voice 2000 voip
description test nvp
destination-pattern 287083079
session protocol sipv2
session target ipv4:192.168.227.70:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3000 voip
destination-pattern 28708307[0-8]
session target ipv4:192.168.227.102:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
in the attachement the output of
"debug voip dialpeer all" and "debug ccsip all"
thanks
davide
Correct Answer by paolo bevilacqua about 7 years 2 months ago
Configure:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Cisco router also do a very good IVR.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 02/10/2010 - 02:28
  • Hall of Fame,
    Founding Member
Repeat with "debug isdn q931" and "debug ccsip message". Do not enable any other debug.
Output will be so reduced that you will be able to read it and will not require attachments to be posted.
If you are using asterisk or similar, note CME on the router does a  much better job especially when used with cisco phones.
Note if you should not use
d.valsania Wed, 02/10/2010 - 02:52
thanks!
I removed the command "isdn bchan-number-order ascending"
and this is the output of  "debug isdn q931" and "debug ccsip message"
from cellphone there are not sip message
the 2 sip server are two Interactive Voice Responder
******from desk phone
C2801-VG-01#
*Feb 10 10:41:09.967: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x37CC
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18384
                Preferred, Channel 4
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, '113168634'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '287083079'
*Feb 10 10:41:09.971: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xB7CC callID = 0x0001 switch = primary-net5 interface = User
*Feb 10 10:41:09.983: ISDN Se0/1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0xB7CC
        Channel ID i = 0xA98384
                Exclusive, Channel 4
*Feb 10 10:41:24.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.227.50:5060;branch=z9hG4bK0F8C
****from cellphone
*Feb 10 10:42:39.215: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x22CF
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
        Channel ID i = 0xA18385
                Preferred, Channel 5
        Calling Party Number i = 0x0183, '3384187978'
                Plan:ISDN, Type:Unknown
        Sending Complete
*Feb 10 10:42:39.215: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xA2CF callID = 0x0002 switch = primary-net5 interface = User
*Feb 10 10:42:39.227: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA2CF
        Channel ID i = 0xA98385
                Exclusive, Channel 5
*Feb 10 10:42:39.231: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xA2CF
*Feb 10 10:42:39.255: ISDN Se0/1/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x22CF
*Feb 10 10:42:39.255: %ISDN-6-CONNECT: Interface Serial0/1/0:4 is now connected to 3384187978 N/A
*Feb 10 10:42:41.699: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:4, changed state to up
*Feb 10 10:42:57.411: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x22CF
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Feb 10 10:42:57.415: %ISDN-6-DISCONNECT: Interface Serial0/1/0:4  disconnected from 3384187978 , call lasted 18 seconds
*Feb 10 10:42:57.415: ISDN Se0/1/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x2
Correct Answer
paolo bevilacqua Wed, 02/10/2010 - 04:09
  • Hall of Fame,
    Founding Member
Configure:
direct-inward-dial
d.valsania Wed, 02/10/2010 - 05:36
thank you very much
now it work!!
why for gsm call I must configure a dial-peer pots?
suggested  documentation?
davide
paolo bevilacqua Wed, 02/10/2010 - 05:46
  • Hall of Fame,
    Founding Member
You must have some other config not included above.
direct-inward-dial is always required.
Related Content
