Is it possible to rename a Call-pickup group, without changing the phones in the group?
In my Cisco Unified CM Administration system version: 7.0.1.11000-2 I have a lot of Call-pickup groups that have a name associating with a department that have changed their name to a new name.
Now I would like to update the Call-pickup groups to the new name, so - by example - if one call-pickup group has the name "Aeldre6", I would like to rename it to "sundhed6" instead.
But I do not want to affect all the phone-numbers associated with the call-pickup group and the number the call-pickup group has.
Can I just rename the Call-pickup-group to the new name, without destroying the group and phones listed in it or do I have to something else?
Kind regards,
Carl-Marius
Brandon Buffin
Yes, you can rename the Call Pickup Group. The new name will be reflected in all currently associated DNs.
Hope this helps.
Brandon
Brandon Buffin
Hope this helps.
Brandon
Hi Brandon,
Thank you for your answer, I will try this then .
Kind regards,
Carl-Marius
