redistributing ospf into eigrp issue
Feb 10th, 2010
Hi all
I have a lab set up, I have created a loopback interface on one router, included this into the ospf process, I have put the command in my eigrp process, redistribute ospf 1, however im not seeing the route injected into eigrp on my other router, why is this?
cheers
Carl
Ganesh Hariharan Wed, 02/10/2010 - 03:37
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
cheers
Carl
Hi Carl,
When a routing protocol is  redistributed into EIGRP,It is necessary to configure the EIGRP metrics that will be applied to the redistributed routes. The metric information could be added to the end of the redistribute ospf command.
default-metric 10000 100 255 1 1500Where  10000 = Bandwidth, 100 = Delay, 255 = Reliability, 1 = Loading, and 1500 =  Maximum Transmission Unit,
Hope that help
Ganesh.H
Giuseppe Larosa Wed, 02/10/2010 - 04:42
  • Hall of Fame,
    Founding Member
Hello Carl,
as noted by Ganeshh EIGRP needs an explicitly defined seed metric to be able to inject external routes from OSPF into EIGRP database.
This is not needed if you redistribute connected or static routes
router eigrp XX
default-metric 10000 10 255 1 1500
red ospf YY
Hope to help
Giuseppe
carl_townshend Wed, 02/10/2010 - 07:02
Hi There
thanks for that,
so, what values would I need to put in? would i also have to put these in if doing the redistribution the other way around, ir eigrp into ospf ?
cheers
Jon Marshall Wed, 02/10/2010 - 07:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
carl_townshend wrote:
Hi There
thanks for that,
cheers
Carl
The values are actually not that important if you are only redistributing on one router. If you are redistributing ospf into eigrp on multiple routers then you could use the values to influence which routes are used and where. The values Giuseppe provided will do fine.
You don't need these values to go the other way. The key things to do when redistributing into OSPF -
1) make sure you include the "subnets" keyword in the redistribute command
2) decide whether the routes will be seen as E1 or E2 external routes
Jon
carl_townshend Wed, 02/10/2010 - 08:39
hi there
what are we telling eigrp when putting the metrics in ? why do we need to put in these metric values ?
Jon Marshall Wed, 02/10/2010 - 10:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
hi there
Carl
All routing protocols use some sort of metric to work out which routes are more preferable to other routers. RIP uses hop count, OSPF uses bandwidth. EIGRP has 5 metrics it can use -
bandwidth of interface
delay
reliability
load
mtu
However by default it only uses 2 of these which are bandwidth and delay and Cisco recommendation is to only use those 2. So you are actually supplying EIGRP with the metrics it needs to calculate which routes are better than others.
Jon
