Change default login time?
Answered Question
Feb 10th, 2010
In my "Cisco Unified CM Administration System version: 7.0.1.11000-2" installation, I can log in to the administration page through the "https://10.10.x.x/ccmadmin/showHome.do" homepage.
Today I am logged out after some 10 minutes of inactivity and have to log on again.
Is there any way that I can change this time-period? (And if this is possible, how do I do this?)
Kind regards,
Carl-Marius
Correct Answer by Rob Huffman about 7 years 1 month ago
Hi Carl-Marius,
Sadly, this is not available to change. This bug/feature request was nicely supplied by Java
CSCsj45520
CM 6.0/7.0 Customer should be able to configure/disable CCMAdmin timeout
Symptom:
Browser session to CCMAdmin times out after 30 minutes and user must re-authenticate.
Conditions:
Browser session to CCMAdmin idle for 30 minutes with CM6.x.
Workaround:
None.  Reauthenticate after 30 minutes of inactivity.
Further Problem Description:
This is an enhancement request to allow configuration of web session timeout.  Please contact Cisco account team or Cisco Product Manager for status, details, and updates about this enhancement request.
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 02/10/2010 - 05:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carl-Marius,
CSCsj45520
Symptom:
Conditions:
Workaround:
Cheers!
Rob
Carl-Marius.Steensen Thu, 02/11/2010 - 04:25
Hi Rob,
Thank you for your fast and precise answer, I will just have to wait until this bug is solved.
Kind regards,
Carl-Marius
Related Content
