Cisco 7606 and ES20 span port problem
Feb 10th, 2010
Is there any way to SPAN(mirror) TX and RX on an Cisco 7606 router with an ES20 card (for downlink - with attached DSLAMs) .
When i try to SPAN the TX i get the following error:
- % EVC port Gi4/0/0 cannot be SPAN TX monitor source due to platform limitation
is there any way to mirror the RX+TX flow  (maybe with netflow? - i don't have access to the router at the moment)
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Wed, 02/10/2010 - 06:15
  • Hall of Fame,
    Founding Member
be aware of SPAN limitations on ES20 :
Switch Port Analyzer (SPAN) Restrictions
Follow these SPAN restrictions when you configure a ES20 line card on the Cisco 7600 series router:
SPAN is not supported on EVC ports.
Traffic is incorrectly relayed to a local SPAN port instead of the SPAN destination port when the following conditions occur:
When the SPAN source and SPAN destination ports belong to ports [0-9] or both ports belong to ports [10-19]
The SPAN source port has a QoS policy-map attached and SPAN traffic matches that policy-map except for class-default.
Using ports [0-9] as SPAN source and [10-19] as SPAN destination or vice versa to avoid the above mentioned limitations.
You cannot use Gi|Te x/0/1 as a SPAN source port when the diagnostic test TestMacNotification is enabled.
see
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES20_config_guide/baldovw.html#wp1111231
So what you see reflects a known limitation.
netflow may be a way to monitor traffic
>> Sampled Netflow
sampled
Hope to help
Giuseppe
cruonit14651 Mon, 03/01/2010 - 18:50
It looks like it's on L2 ports  (trunk Dot1Q mode) so the flow-sampler can't capture the L2 traffic, it' works only on L3 ports (neither with MPLS packets)
Any idea ?
Related Content
