Cisco VPN client with Ericsson W35 router
Feb 10th, 2010
I have an issue when trying to configure a VPN client version 4.8.01 thru an Ericson W35 router.
I'm able to connect the client software to my Pix, but cannot access any machine inside the tunnel.  The same config thru a different router works correctly.
Any suggestion will be appreciate
Jacques Lapointe Mon, 04/05/2010 - 11:48
  • Cisco Employee,
I use VPN client 5.0.03, and it works fine (although it looses connection once every other day). I've talked to Rogers Technical Support (and they don't support and can't garantee VPN will work through the Rocket Hub), it seems to be a known issue with the device (and associated apn proxy). My IPSec connection (from a Cisco Router) will work about 40 minutes, but then drops for no apparent reason. That's why I have to use the VPN client.
So, Rogers won't support, and can't find anything valuable on Ericsson/s web site. And yet, the W35 is still an impressive little gadget.
