02-10-2010 06:37 AM - edited 03-18-2019 11:05 AM
Hi all,
I have a 2801 router. I inserted a VWIC2-1MFT-T1/E1 card. I configured it on a CUCM 7.1 by adding a new gateway using MGCP (I want it work using QSIG).
On the router I inserted the following commands:
no ip domain-lookup
mgcp
ccm-manager config server 172.17.7.5
ccm-manager config
exit
wr mem
After inserting these commands I could see the following debug:
Loading MU-GW-2801.cnf.xml from 172.17.7.5 (via FastEthernet0/0): !
[OK - 4749 bytes]
MU-GW-2801#
*Feb 10 11:43:57.786: %SYS-5-CONFIG_I: Configured from console by admin on console
This package type is not the default package type.
isdn switch-type primary-4ess
% Invalid input detected at '^' marker.
Could anyone help on what is the matter? I have tried several IOS:
- c2801-adventerprisek9-mz.124-24.T2.bin
- c2801-advipservicesk9-mz.124-24.T2.bin
- c2801-entservicesk9-mz.124-24.T2.bin
I thought it could be that the command was not supported. But, none of these IOS worked.
Thank you very much,
JOSU
02-10-2010 06:49 AM
There are alot more commands you need to add try
pri-group timeslots 1-?? service mgcp
under controller interface
isdn bind-l3 ccm-manager
under serial interface
then these addtional commands
ccm-manager mgcp
ccm-manager music-on-hold
mgcp
mgcp call-agent "IP address of callmanager "service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
You need to make sure that in Callmanager the port says "registered" if it doesn't then you have the configuration wrong
02-10-2010 09:35 AM
Thank you very much for your answer markbatts
I discovered I had a problem. I saw this on the running-conf: "card type command needed for slot/vwic-slot 0/1".
So I introduced the command "card type e1 0 1". So, after that I saw "controller E1 0/1/0" on running. I was quite surprised not to see it before.
Afterwards I re-enter the commands:
- mgcp
- ccm-manager config server 172.17.7.5
I got this result:
[OK - 4757 bytes]
I checked the running-config and I saw these new lines:
isdn switch-type primary-5ess
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 172.17.7.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
no mgcp package-capability res-package
mgcp sdp simple
mgcp profile default
But when I checked on the CUCM I saw that it still appeared as "unregistered". So I selected the gateway and reset it. Doing so, I got these entries in gateway's console:
%Please configure network-clock-participate wic 1 first
%Insufficient resources to create pri-group - it has been removed
interface Serial0/1/0:15
What am I missing? I do not have any serial interface. Those commands are which you told me in your answer. Why should I have a serial interface. I am quite new in MGCP so every help is welcommed...
THANK YOU VERY MUCH
JOSU
02-10-2010 09:40 AM
Hi again,
I keep making some tries. The first line of the errors was:
So I introduced the command "MU-GW-2801(config)#network-clock-participate wic 1". Afterwards I reset the gateway from the CUCM and I got these error:
echo-cancel coverage 8
%At least one pri-group was configured already for E1 0/1/0
Please remove it before changing timing mode.
*Feb 10 17:35:38.979: voice_port is not initialized
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:0, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:1, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:2, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:3, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:4, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:5, changed state to down
*Feb 10 17:35:39.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:6, changed state to down
*Feb 10 17:35:39.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:7, changed state to down
*Feb 10 17:35:39.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:15, changed state to down
I can see now the serial interface. But, I do not know how to solve the pri-group issue..
THANK YOU!!!
JOSU
