LMS RME Compliance Mgtm - Template Question
Answered Question
Feb 10th, 2010
Hello
I have LMS 3.2 on Windows. I have a question about compliance template. How I can describe unknown values in template? For example: I have routers with 2 - 3 syslog server (on each router they are different) and I want remove all of them and add new.
Stanislav Kuchma
Correct Answer by Joe Clarke about 6 years 11 months ago
With two servers, try:
+   logging   10.0.0.1
+   logging   10.0.0.2
-   logging  [#!(10\.0\.0\.1|10\.0\.0\.2)#]
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 02/10/2010 - 16:40
Assuming the syslog server you want is 10.1.1.1, do:
+ logging 10.1.1.1
- logging [#(?!10\.1\.1\.1)#]
Support Team Sat, 02/13/2010 - 07:05
I have syslog 10.0.0.1 10.0.0.2 (and in routers config i have several "bad" syslog with "random" addresses):
If i wrote:
+   logging   10.0.0.1
+   logging   10.0.0.2
-   logging  [#?!(10\.0\.0\.1)#]
RME tries remove all syslog servers ("good" and "bad")
If i wrote:
+   logging   10.0.0.1
+   logging   10.0.0.2
-   logging  [#(?!10\.0\.0\.1)#]
RME says ok and don't remove "bad" servers
Correct Answer
Joe Clarke Sat, 02/13/2010 - 10:47
+   logging   10.0.0.1
+   logging   10.0.0.2
