ssh configuration pix 535
Feb 10th, 2010
I have a pix 535 that has been configured to allow SSH, i can get to it remotely, and get prompted for a password.
I assumed this was the default either pix or cisco, but neither appear to be working...
Am I missing another default password somewhere?
I'd like to set it up to prompt for a username/password, but can find no configuration to turn this on (such as a vty session config like on a switch).
any thoughts would be appreciated...
Bruce
bthompson001 Wed, 02/10/2010 - 09:44
Did you try
aaa authentication ssh console LOCAL
That should prompt you for Uname and PW.
Bruce Summers Wed, 02/10/2010 - 09:50
I haven't tried that...I would like to see if I can determine this default p/w issue..
I can console into the pix, and it takes me straight into user mode. Enable mode doesn't have a p/w set...so, I'm able to confiugre whatever I need (so far)...
I don't want to lock myself out of this
Bruce Summers Wed, 02/10/2010 - 09:52
bthompson001 Wed, 02/10/2010 - 10:04
The default username/password for the Pix is
username - pix
password - cisco
you won't lock yourself out. no worries there.
what prompt are you seeing when you console in?
pix>
or
ciscopix>
Bruce Summers Wed, 02/10/2010 - 10:25
The aaa local worked...
I set a local user account, turned it on....it doesn't prompt for the username, but the password definately is the one I set...
What is that prompt that I was getting?? I thought it shoukd have been the default, but that did not work at all...
Bruce Summers Wed, 02/10/2010 - 12:19
Let me ask you another question...
What I have setup, is an ssh capability from one of my aggregation switches to this pix.
So, I setup an L3 interface (between the switch and the Pix), and am using the switch to jump into the pix...
However, once I get into user mode on the pix, I attempt to access exec mode, and it is hung at the user mode prompt. No ability to run any command, let alone the enable command.
If I go to the switch that I'm using to jump from, plug into the console, it works fine...I can ssh to the Pix, accesses user mode, enter enable, and takes me right into exec mode...
Bruce Summers
Data Center O&M
Network Engineering Services
Department of Homeland Security | DC-1
9325 Cypress Loop Rd | Stennis Space Center, MS 39529
Office: 228.813.4838 | Mobile: 202.502.7628 | EMOC: 866.972.EMOC
