Time of Day Routing 6.x.x
Feb 10th, 2010
I have created a Time Periods and
Time Schedules for Time of Day Routing. When I try to Delete a Time Schedule this is what I get:
Error occurred. One or more record did not get deleted. The pkid column in the timeschedule table in the database is being referenced from another table. Please check the dependency records, remove the reference, and then try the delete again.
How can I make it so I can delete a Time Schedule not wanted any more?
Thanks In Advance!
Brandon Buffin Wed, 02/10/2010 - 10:15
  • Purple, 4500 points or more
Sounds like your time schedule is being referenced by a partition. If you have dependency records enabled, choose the time schedule and then Dependency Records under Related Links and this will tell you which partition is using the time schedule.
Hope this helps.
Brandon
Jaime Valencia Wed, 02/10/2010 - 10:15
  • Cisco Employee,
  • Hall of Fame,
    2011
Do as instructed by the message, look at the dependency records to see where you're still using it, remove the time schedule from those elements and then retry to delete
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
