MDI on newer switches
Are there any advantages to still using crossover cables between newer switches which support mdix auto?
Carlos
2 Accepted Solutions
Jerry Ye
Yes. If you want to hard code the duplex and speed, you will need to use crossover cable. Hence, hard code duplex and speed will turn off auto MDIX.
HTH,
jerry
insomniacgames_nc wrote:
is it best practices to hard code speed and duplex on
switch to switch ports to eliminate potential problems in auto-negotiation?
Carlos
Not necessarily. Gigabit is often best left to auto-negotiate. 10/100 interconnects in the past i have tended to hardcode speed/duplex. But obviously if you are using mdix you can't anyway.
Jon
Jerry Ye
HTH,
jerry
Carlos
Carlos
Jon
I personally do not use MDI and use crossover patches anyway since they will work on any switch. I also color code them so it's easier to find problems when a trunk goes down.
I was just curious if MDI is best to stay away from if given the choice.
Carlos
