2800 Router need config example simple VPN local username DB
I need a config example on how to setup VPN on a 2800 router using local usernames database and pre-shared key or whatever is the simplest.
Nothing special needed here.
All the examples are for special features like Radius authen.
I just want to use our Cisco VPN clients (4.7.00.0533) to connect to this remote 2800 router which has a 3G Sprint cellular outside interface NAT w/Overload.
Thanks.
hdashnau Wed, 02/10/2010 - 12:34
  • Cisco Employee,
Keith,
This document might be a little bit more than you need (it assumes you also want to send the VPN client traffic over an existing VPN), but I picked it because it has a complete example of software based VPN client connection to a router using local authentication and it also shows you how to exempt the VPN client traffic from NAT:
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a00809c7171.shtml#add
Some notes to make the document fit your scenario:
-Your NAT_Exempt ACL will just be sourced from your inside network (or any) going to the VPN pool. You dont need the L2L networks defined.
-You can skip step 3 entirely. You dont need to define any L2L information.
-Step 4, your ACL just needs to be sourced from your inside network to the VPN pool. You dont need the L2L networks defined.
-heather
This document overwelms me.
I only have one router in this particular situation.
Why would I need a ACL to disable NAT if there are no other branch office routers?
Let me try a different aproach.
Below is my current config.
What am I missing?
Thanks.
Current configuration : 2977 bytes
version 12.4
service password-encryption
hostname "--Removed--"
boot-start-marker
boot-end-marker
enable secret "--Removed--"
enable password "--Removed--"
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.100 192.168.1.254
ip dhcp pool Ethernet_0_pool
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 206.228.179.10 144.228.254.10 144.228.255.10
ip domain name dyndns.org
ip name-server 206.228.179.10
ip ddns update method dyndnsdotorg
HTTP
  add &myip=http://user:[email protected]/nic/update?system=dyndns&hostname=&myip=>
chat-script cdma "" "ATDT#777"  TIMEOUT 60 "CONNECT"
password encryption aes
username user password "--Removed--"
archive
log config
  hidekeys
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/3/0
ip dhcp client update dns
ip ddns update hostname "--Removed--"
ip ddns update dyndnsdotorg
ip address negotiated
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string cdma
dialer-group 1
async mode interactive
ppp chap password "--Removed--"
interface Async0/1/0
no ip address
encapsulation slip
ip local pool VPNpool 192.168.2.100 192.168.2.200
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Cellular0/3/0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Cellular0/3/0 overload
logging trap debugging
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 remark Nat Access-List
access-list 2 permit any
access-list 2 remark triggers Cellular0/3/0 to dial.
dialer-list 1 protocol ip list 2
control-plane
line con 0
line aux 0
line 0/1/0
login
modem Dialin
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line 0/3/0
script dialer cdma
no exec
rxspeed 3100000
txspeed 1800000
line vty 0 4
login
scheduler allocate 20000 1000
ntp clock-period 17180000
ntp source Cellular0/3/0
ntp peer 129.6.15.28
end
