ACS 5.1 backup not working
Hi there
we would like to save the backup of an ACS 5.1 to a NFS: \\x.x.x.x\ACS_Backup
We configured the ip x.x.x.x and the share name as /ACS_Backup, is this correct? I can mount this share with the configured username / password, but the ACS can't backup to the share. Is there a way to see the problem in the logs?
Dominic
Ganesh Hariharan
Hi there
Dominic
Hi Dominic,
Check out the below link hope that help
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_upg.html
Ganesh.H
20vek
can you read repository? I would place some files there and
do "show repository ACS_Backup". You should be able to see these files.
I use ftp. works fine.
and it should be forward slashes. nfs://x.x.x.x./ACS_Backup
Ganesh Hariharan
Hi there
Dominic
Hi Dominic,
Ganesh.H
Hi both of you
thanks for your feedback. I will try this and will post it again.
Thanks and regards
Dominic
hi,
I've got different question,
What size of disk space is necessary to maintaine regular scheduled backups?
what is being backup?
regards
