IP SLA/EEM running out of VTY lines and failing
Doug Boreham
I am using IP SLA to ping network devices to detect network failures from an AS5400XM voice gateway.  The AS5400XM platform is limited to 5 vty lines ( vty 0 4).  When simulating a simultaneous outage, there are not enough tty lines available to process my EEM events.
However, when simulating a simultaneous outage, we have a new issue – there are not enough lines available:
Feb  9 15:16:22.970 CST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
Feb  9 15:16:22.970 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ReportIPSLAevent_1005065020_up statement 1.1
Feb  9 15:16:22.974 CST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
Feb  9 15:16:22.978 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ReportIPSLAevent_1005081020_up statement 1.1
Feb  9 15:16:22.986 CST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
Feb  9 15:16:22.986 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ReportIPSLAevent_100000226_up statement 1.1
Feb  9 15:16:22.994 CST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
Feb  9 15:16:22.994 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ReportIPSLAevent_1001012021_up statement 1.1
Feb  9 15:16:23.006 CST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
Feb  9 15:16:23.006 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ReportIPSLAevent_1061247018_up statement 1.1
How can I detect/wait until there are enough lines free before processing the EEM rules?
-Doug
Yeah, this debug output looks good.  The SMTP server accepted the message, and it should get delivered to receipient@mydomain.com.  If not, you would need to debug things from the SMTP side.
As for the subject, it looks like you may not be using the very latest version of the script I sent out.  I attempted to workaround the bug you're seeing in that version.  You should see lines in the script like:
if { $target_ip == "0.0.0.0" } {
   set traget_ip $source_ip
23 Replies 23
Joe Clarke
Post your current applet policy.  What version of IOS is this router running?
ip sla responder
ip sla logging traps
ip sla 100000226
icmp-echo 10.0.0.226 source-interface Loopback0
request-data-size 200
tos 184
history hours-of-statistics-kept 3
history lives-kept 1
history enhanced interval 900 buckets 100
ip sla schedule 100000226 life forever start-time now
ip sla 100500226
icmp-echo 10.5.0.226 source-interface Loopback0
tos 184
ip sla schedule 100500226 life forever start-time now
ip sla 100564197
icmp-echo 10.5.64.197 source-interface Loopback0
tos 184
ip sla schedule 100564197 life forever start-time now
ip sla 1001011011
icmp-echo 10.0.11.11 source-interface Loopback0
tos 184
ip sla schedule 1001011011 life forever start-time now
ip sla 1001012021
icmp-echo 10.0.12.21 source-interface Loopback0
tos 184
ip sla schedule 1001012021 life forever start-time now
ip sla 1005019195
icmp-echo 10.5.19.195 source-interface Loopback0
ip sla 1005065020
icmp-echo 10.5.65.20 source-interface Loopback0
tos 184
ip sla schedule 1005065020 life forever start-time now
ip sla 1005081020
icmp-echo 10.5.81.20 source-interface Loopback0
tos 184
ip sla schedule 1005081020 life forever start-time now
ip sla 1061247018
icmp-echo 10.61.247.18 source-interface Loopback0
tos 184
ip sla schedule 1061247018 life forever start-time now
ip sla reaction-configuration 100000226 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 100500226 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 100564197 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 1001012021 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 1005065020 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 1005081020 react timeout threshold-type xOfy 3 5 action-type trapOnly
ip sla reaction-configuration 1061247018 react timeout threshold-type xOfy 3 5 action-type trapOnly
event manager environment _mail_smtp my.nameserver.com
event manager environment _mail_rcpt myemailaddress@mydomainname.com
event manager environment _mail_domain mydomainname.com
event manager applet weekdays
event timer cron name weekdays cron-entry "0 9 * * 1-5"
action 1.00001 cli command "enable"
action 1.00002 cli command "conf t"
action 1.00381 cli command "dial-peer voice 38 voip"
action 1.00382 cli command "max-conn 0"
action 1.14851 cli command "dial-peer voice 1485 voip"
action 1.14852 cli command "max-conn 0"
action 9.99997 cli command "end"
action 9.99998 cli command "wr mem"
action 9.99999 cli command "exit"
event manager applet afterhours
event timer cron name afterhours cron-entry "0 21 * * 1-5"
action 1.00382 cli command "max-conn "
action 1.14852 cli command "max-conn "
event manager applet weekends
event timer cron name weekends cron-entry "1 21 * * 5"
event manager applet ReportIPSLAevent_100000226_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100000226.* Threshold Occurred for timeout"
action 1.0     info type routername
action 1.1     cli command "show ip sla statistics 100000226"
action 2.0     mail server "$_mail_smtp" to "$_mail_rcpt" from "$_info_routername@$_mail_domain" subject "IP SLA alert - $_info_routername connectivity to [other_server] is down" body "$_cli_result"
event manager applet ReportIPSLAevent_100000226_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100000226.* Threshold Cleared for timeout"
action 2.0     mail server "$_mail_smtp" to "$_mail_rcpt" from "$_info_routername@$_mail_domain" subject "IP SLA alert - $_info_routername connectivity to [other_server] has been restored" body "$_cli_result"
event manager applet ReportIPSLAevent_100500226_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100500226.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 100500226"
event manager applet ReportIPSLAevent_100564197_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100564197.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 100564197"
event manager applet ReportIPSLAevent_1001011011_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1001011011.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1001011011"
event manager applet ReportIPSLAevent_1001012021_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1001012021.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1001012021"
event manager applet ReportIPSLAevent_1005065020_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005065020.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1005065020"
event manager applet ReportIPSLAevent_1005081020_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005081020.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1005081020"
event manager applet ReportIPSLAevent_1005019195_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005019195.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1005019195"
event manager applet ReportIPSLAevent_1061247018_down
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1061247018.* Threshold Occurred for timeout"
action 1.1     cli command "show ip sla statistics 1061247018"
event manager applet ReportIPSLAevent_100500226_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100500226.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_100564197_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*100564197.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1001011011_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1001011011.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1001012021_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1001012021.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1005065020_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005065020.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1005081020_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005081020.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1005019195_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1005019195.* Threshold Cleared for timeout"
event manager applet ReportIPSLAevent_1061247018_up
event syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*1061247018.* Threshold Cleared for timeout"
end
Do you want to maintain all of these separate syslog policies?  They could be combined into one.
Sure - I would be open to combining them.  I'm relatively new to writing EEM programs, so I am open to suggestions on ways to streamline the configuration.
-Doug
Here you go.  This policy should replace all of your occurred and cleared IP SLA applets.  It will also automatically scale to any new IP SLA collectors you create.  You will need to first create a directory on local flash to store EEM Tcl policies.  Then copy this script into that directory (I use something like flash:/policies).  Then configure the following:
event manager directory user policy POLDIR
event manager policy sl_ip_sla_report.tcl
Where POLDIR is the directory where you copied the sl_ip_sla_report.tcl script.
Be sure to remove all of your IP SLA applet policies first.
Joe,
Thanks for the update.  I now realize that I missed giving you a key piece of information.  In order to not list the specific hostnames in this post, I removed those individual names and replaced it with the generic text "[other_server]"
Subject: IP SLA alert - $_info_routername connectivity to [other_server]
There is a specific server tied to each IP SLA poll, and I want the e-mail subject to reflect the hostname of the IP address being polled.  In most but not all cases, that hostname is registered in DNS if that helps.
For example, in the code:
ip sla 100000226
tos 184
ip sla 100500226
tos 184
let's say that the hostname of 10.0.0.226 is appserver01 and the hostname of 10.5.0.226 is devbox.  I would want to send out e-mails with the following respective subjects if ping [fails/restores]:
For 10.0.0.226:
Subject: IP SLA alert - $_info_routername connectivity to appserver01 {is down | has been restored}
For 10.5.0.226:
Subject: IP SLA alert - $_info_routername connectivity to devbox {is down | has been restored}
-Doug
Try this version.  You will need to first set an environment variable for each IP-to-hostname mapping.  For example, if 10.0.0.226 maps to appserver01, and 10.5.0.226 maps to devbox, add:
event manager environment hostname_10_5_0_226 devbox
event manager environment hostname_10_0_0_226 appserver01
Do this for each IP SLA target IP.
Joe,
I am getting a compilation error:
show debug
General OS:
  Event Manager debugging is on
Embedded Event Manager:
  Debug EEM Tcl commands debugging is on
router(config)#event manager policy sl_ip_sla_report.tcl
EEM configuration: failed to create the event spec for policy sl_ip_sla_report.tcl: regular expression compilation error
router(config)#
Feb 16 14:38:17.069 CST: fh_tcl_get_mode: mode = 3, StartupScript = flash:/policies/sl_ip_sla_report.tcl, RealScript = flash:/policies/sl_ip_sla_report.tcl
Feb 16 14:38:17.073 CST: fh_tcl_assoc_data_delproc: freeing tctx=0x64E304BC
Feb 16 14:38:17.077 CST: fh_tcl_get_mode: mode = 0, StartupScript = flash:/policies/sl_ip_sla_report.tcl, RealScript = flash:/policies/sl_ip_sla_report.tcl
Feb 16 14:38:17.077 CST: fh_set_tclpath_global: tcl_library is set to tmpsys:/lib/tcl
Feb 16 14:38:17.077 CST: fh_set_tclpath_global: auto_path is set to tmpsys:/eem_lib_user tmpsys:/eem_lib_system
Feb 16 14:38:17.077 CST: fh_register_evreg_cmds: tctx=64E304BC, dummy=0
Feb 16 14:38:17.081 CST: fh_register_event_cmn: filename=flash:/policies/sl_ip_sla_report.tcl
Feb 16 14:38:17.085 CST: fh_event_register_cmd: policy_name=sl_ip_sla_report.tcl
Feb 16 14:38:17.085 CST: fh_event_register_cmd: stmt=::cisco::eem::event_register_syslog#pattern#RTT-3-IPSLATHRESHOLD: IP SLA.*+.* Threshold (Cleared|Occurred) for timeout#
Feb 16 14:38:17.085 CST: EM: No consumer registered for any event type
Feb 16 14:38:17.085 CST: Keyword: pattern Argument: "RTT-3-IPSLATHRESHOLD: IP SLA.*+.* Threshold (Cleared|Occurred) for timeout"
Feb 16 14:38:17.085 CST: fh_event_register_cmd: rc=0
Feb 16 14:38:17.085 CST: fh_tcl_assoc_data_delproc: freeing tctx=0x64E304BC
It looks like you modified my script.  The first line should read:
::cisco::eem::event_register_syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*[0-9]+.* Threshold (Cleared|Occurred) for timeout"
This is a valid regular expression.
Joe,
There must be some other reason, as the script was installed as sent via FTP.
vgw01.it.wstia#dir
Directory of flash:/policies/
   15  -rw-        1922  Feb 16 2010 14:34:44 -06:00  sl_ip_sla_report.tcl
128733184 bytes total (95617024 bytes free)
Variables:
event manager environment __easy_PREFIX flash:/easy
event manager environment _mail_smtp mailserver.mydomain.com
event manager environment _mail_rcpt hiddenemail@mydomain.com
event manager environment _mail_domain mydomain.com
event manager environment hostname_10_0_0_226 hostname01
event manager environment hostname_10_5_64_197 hostname02
event manager environment hostname_10_0_12_21 hostname03
event manager environment hostname_10_0_11_11 hostname04
event manager environment hostname_10_0_11_12 hostname05
event manager environment hostname_10_5_81_20 hostname06
event manager environment hostname_10_8_19_20 hostname07
Here is the script from the router:
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set _sinfo [sys_reqinfo_routername]
set _info_routername $_sinfo(routername)
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
array set arr_einfo [event_reqinfo]
set msg $arr_einfo(msg)
if { ! [regexp {RTT-3-IPSLATHRESHOLD: IP SLA.*\(([0-9]+)\).* Threshold (Cleared|Occurred) for timeout} $msg -> collector type] } {
    action_syslog msg "Failed to find collector ID in syslog"
    exit 1
if [catch {cli_exec $cli1(fd) "show ip sla statistics $collector"} iplsa_stat] {
    error $ipsla_stat $errorInfo
set stat {is down}
if { $type == "Cleared" } {
    set stat {has been restored}
if { [catch {cli_exec $cli1(fd) "show ip sla conf $collector"} _cli_result] } {
    error $_cli_result $errorInfo
set other_server {Unknown}
if { [regexp {Target address: ([0-9\.]+)} $_cli_result -> target_ip] } {
    regsub -all {\.} $target_ip {_} varname
    if { [info exists hostname_${varname}] } {
        set other_server [expr "\$hostname_$varname"]
     } else {
         set other_server $target_ip
set mail_pre "Mailservername: $_mail_smtp\n"
append mail_pre "From: $_info_routername@$_mail_domain\n"
append mail_pre "To: $_mail_rcpt\n"
append mail_pre
append mail_pre "Subject: IP SLA alert - $_info_routername connectivity to $other_server $stat\n\n"
append mail_pre "$ipsla_stat\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
if [catch {smtp_send_email $mail_msg} result] {
if [catch {cli_exec $cli1(fd) "exit"} _cli_result] {
# Close open cli before exit.
if [catch {cli_close $cli1(fd) $cli1(tty_id)} result] {
-Doug
Ugh, now that you display what I sent I see the problem.  The regexp in the ED line is invalid Tcl.  You need to put a '\' in front of the '[':
::cisco::eem::event_register_syslog pattern "RTT-3-IPSLATHRESHOLD: IP SLA.*\[0-9]+.* Threshold (Cleared|Occurred) for timeout"
That will work.
Joe,
There appears to be an error - Tcl policy execute failed: can't read "ipsla_stat": no such variable:
show debug
General OS:
IP SLAs:
TRACE debugging for all operations is on
Debug EEM Tcl CLI library debugging is on
Debug EEM Tcl SMTP library debugging is on
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : IP SLAs, Infrastructure Engine-II.
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Entry number: 1061247018
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Owner:
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Tag:
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Type of operation to perform: icmp-echo
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Target address/Source address: 0.0.0.0/10.61.247.18
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Operation timeout (milliseconds): 5000
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Type Of Service parameters: 0xB8
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Vrf Name:
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Request size (ARR data portion): 200
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Verify data: No
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Schedule:
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Operation frequency (seconds): 60 (not considered if randomly scheduled)
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Next Scheduled Start Time: Start Time already passed
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Group Scheduled : FALSE
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Randomly Scheduled : FALSE
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Life (seconds): Forever
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Entry Ageout (seconds): never
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Recurring (Starting Everyday): FALSE
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Status of entry (SNMP RowStatus): Active
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : CTL : 20+ lines read from cli_read, debug output truncated.
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: can't read "ipsla_stat": no such variable
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: while executing
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: "append mail_pre "$ipsla_stat\n\n""
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: invoked from within
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: "$slave eval $Contents"
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: (procedure "eval_script" line 7)
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: "eval_script slave $scriptname"
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: "if {$security_level == 1} { #untrusted script
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: interp create -safe slave
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: interp share {} stdin slave
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: interp share {} stdout slave
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: ..."
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: (file "tmpsys:/lib/tcl/base.tcl" line 50)
Feb 17 12:57:37.837 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: Tcl policy execute failed:
Feb 17 12:57:37.841 CST: fh_tcl_esi_close: fd=11
Feb 17 12:57:37.841 CST: fh_tcl_esi_close: fd=12
Feb 17 12:57:37.841 CST: fh_tcl_assoc_data_delproc: freeing tctx=0x69968274
-Doug
I had another typo.  Here is a fixed version.
Joe,
I think we're getting close!
Now we get an error on the e-mail portion - Tcl policy execute failed: %HA_EM-6-LOG: sl_ip_sla_report.tcl: wrong 4th line format:
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : IP SLAs, Infrastructure Engine-II.
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Entry number: 1005081020
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Owner:
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Tag:
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Type of operation to perform: icmp-echo
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Target address/Source address: 0.0.0.0/10.5.81.20
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Operation timeout (milliseconds): 5000
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Type Of Service parameters: 0xB8
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Vrf Name:
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Request size (ARR data portion): 200
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Verify data: No
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Schedule:
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Operation frequency (seconds): 60 (not considered if randomly scheduled)
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Next Scheduled Start Time: Start Time already passed
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Group Scheduled : FALSE
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Randomly Scheduled : FALSE
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Life (seconds): Forever
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Entry Ageout (seconds): never
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Recurring (Starting Everyday): FALSE
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : OUT : Status of entry (SNMP RowStatus): Active
Feb 17 14:09:30.669 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl : DEBUG(cli_lib) : CTL : 20+ lines read from cli_read, debug output truncated.
Feb 17 14:09:30.673 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: wrong 4th line format.
Feb 17 14:09:30.673 CST: %HA_EM-6-LOG: sl_ip_sla_report.tcl: usage: Cc:
Feb 17 14:09:30.677 CST: fh_tcl_esi_close: fd=11
Feb 17 14:09:30.677 CST: fh_tcl_esi_close: fd=12
Feb 17 14:09:30.677 CST: fh_tcl_assoc_data_delproc: freeing tctx=0x6B0ED1CC
-Doug
