Create Instance of a Step in the Expression Editor
Feb 10th, 2010
I am trying to create an instance of a step inside of the expression editor. Are these classes implemented in the expression editor, what packages are they in/what are the classes called, and is there any documentation on this? Thanks in advance for any responses.
Anthony Holloway Thu, 02/25/2010 - 09:38
If you are a member of the Cisco Developer community, you can go to the UCCX section and download the UCCX SDK, which has examples of how to do this.
Tanner Ezell Thu, 02/25/2010 - 09:55
What SDK are you referring to? Cisco's Developer website has the protocol information for UCCXCTI but I am unaware of an SDK.
Anthony Holloway Fri, 02/26/2010 - 15:52
Oops, you are correct, it's not there.
It's actually on your server in:  C:\Program Files\wfavvid\workflowsdk
Thanks, good catch.
