ANM, ACE module device type
Feb 10th, 2010
I have a pair of ACE modules installed and maintained through ANM.  We
started with ANM 2.X and recently upgraded to 3.0.
The ACE modules were running code A1(6.3) and are now on A2(2.3).
ANM is identifying the devices as Device Type ACE v1.0, and device types
seem to limit the features that ANM exposes for configuration.
The GUI does not expose the HTTP/SSL rewrite features in Expert mode, but I
can configure the devices in the CLI.
I have been unable to find an info on how devices are identified, or if they type
can be changed..
The exact module installed is a ACE20-MOD-K9.  Can anyone shed some light
on if this is an 'ACE V1.0' and if not, how to convince ANM of the correct type?
Marvin Rhoads Sat, 02/13/2010 - 07:19
Just a thought - when you upgraded did you change the default www user password on the ACEs? I remember the upgrade instructions instructing that this step was necessary to allow manipulation of the configuration via xml (which I believe the ANM tool requires to exercise its full functionality).
