Windows Vista/Xp Wireless client could not connect to AP-1131AG with WPA
rawsonfang
This is my setup:
1. Cisco Automuous AP - 1131AG-A-K9figure with 3 VLANs and 3 SSIDs, one SSID for each VLAN.
2. Running code version: c1130-k9w7-mx.124-10b.JDA3
3. first SSID - faculty-1,VLAN201 , confiure with Cipers TKIP and WPA, and passphrase.
4. Seccondary SSID - faculty-2,VLAN202 , confiure with WEP
5. Third SSID- guest. VLAN203, no encryption.
6. Use Windows VISTA laptop with Window wireless client , could connect to both the secondary and third SSID, but the connection to First SSID with WPA keep failing.
Any idea,thanks for the advice.
7 Replies 7
Leo Laohoo
In order to help in troubleshooting, can you make all of the SSIDs use OPEN or no authentication?  If it still doesn't work, can you post your config?
All the SSIDs were configured with Open authentication, WEP and no authentication work, but WPA. attached please find the configuration.Thanks
DFx-WL-AP002#
hostname IDFx-WL-AP002
enable secret 5 $1$x2cF$CowZYf0R5M3yf14ZP695z/
no aaa new-model
dot11 ssid faculty-1
   wpa-psk ascii babb1122babb
   vlan 201
   authentication open
   authentication key-management wpa
   mobility network-id 201
dot11 ssid faculty-2
   vlan 202
   authentication open
dot11 ssid guest
   vlan 203
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio1
encryption vlan 201 mode ciphers tkip
no ip address
no ip route-cache
encryption vlan 200 mode ciphers wep128
encryption vlan 202 key 1 size 40bit 7 397CB7630AE1 transmit-key
encryption vlan 202 mode wep mandatory
encryption vlan 201 mode ciphers aes-ccm
ssid faculty-1
ssid faculty-2
ssid guest
mbssid
station-role root
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.201
encapsulation dot1Q 201
no ip route-cache
bridge-group 201
bridge-group 201 subscriber-loop-control
bridge-group 201 block-unknown-source
no bridge-group 201 source-learning
no bridge-group 201 unicast-flooding
bridge-group 201 spanning-disabled
interface Dot11Radio0.202
encapsulation dot1Q 202
no ip route-cache
bridge-group 202
bridge-group 202 subscriber-loop-control
bridge-group 202 block-unknown-source
no bridge-group 202 source-learning
no bridge-group 202 unicast-flooding
bridge-group 202 spanning-disabled
interface Dot11Radio0.203
encapsulation dot1Q 203
no ip route-cache
bridge-group 203
bridge-group 203 subscriber-loop-control
bridge-group 203 block-unknown-source
no bridge-group 203 source-learning
no bridge-group 203 unicast-flooding
bridge-group 203 spanning-disabled
no ip address
no ip route-cache
encryption vlan 202 key 1 size 40bit 7 76A8B820E4B6 transmit-key
ssid faculty-1
ssid faculty-2
ssid guest
station-role root
bridge-group 1
interface Dot11Radio1.201
no ip route-cache
bridge-group 201
interface Dot11Radio1.202
no ip route-cache
bridge-group 202
interface Dot11Radio1.203
no ip route-cache
bridge-group 203
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.200
no ip route-cache
bridge-group 1
interface FastEthernet0.201
no ip route-cache
bridge-group 201
interface FastEthernet0.202
no ip route-cache
bridge-group 202
interface FastEthernet0.203
no ip route-cache
bridge-group 203
interface BVI1
ip address 10.128.1.2 255.255.255.0
no ip route-cache
ip default-gateway 10.128.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
Message was edited by: rawsonfang
Can you also remove the encryption to VLAN 202 and 203?
Vlan203 - SSID- guest, works fine without encryption. so sure if this was due to my Laptop issue because of Windows Vista bug with WPA compatibility?
rawsonfang....
      I may be missing something, but I think I'm seeing 2 "interface Dot11Radio1" in your configuration.  Is this a typo?  Also, under the first Dot11Radio1 you are using AES and TKIP....as a best practice you should stick to TKIP with WPA and AES with WPA2.  Let me know if this helps.
This is latest config:
IDFx-WL-AP002#sh run
Building configuration...
Current configuration : 4456 bytes
version 12.4
no service pad
service password-encryption
no aaa new-model
vlan 201
authentication open
wpa-psk ascii 7 00251125005E0D272E006D6F28382436330A0E072E2E2209311626
no ids mfp client
vlan 202
authentication open
dot11 ssid guest
vlan 203
authentication open
guest-mode
bridge irb
no ip address
no ip route-cache
encryption vlan 202 key 1 size 128bit 7 5C8396957C974FD578D183FB82F3 transmit-k
ey
ssid faculty-1
ssid faculty-2
ssid guest
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 201
no ip route-cache
bridge-group 202
no ip route-cache
bridge-group 203
no ip address
no ip route-cache
encryption vlan 202 key 1 size 128bit 7 8EC1CAB5D9AFBDB688B9CEDE6DC1 transmit-k
ey
ssid faculty-1
ssid faculty-2
ssid guest
station-role root
bridge-group 1
no ip route-cache
bridge-group 201
no ip route-cache
bridge-group 202
no ip route-cache
bridge-group 203
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 201
no ip route-cache
bridge-group 202
no ip route-cache
bridge-group 203
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
IDFx-WL-AP002#$
Do you have a WLSM?  I assume no, since you didn't mention it in the first place.  If you don't, remove the mobility network-id 201 from faculty-1 and see if that helps
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
