Uploading Custom Code jar file onto UCCX
Feb 10th, 2010
     I have written a custom code in java that invokes a web service. Now, this web service internally is dependent on jar files from IBM. My challenge is to upload my custom code jar file into the CRS admin page under Document Management. The custom code is dependent on the huge ibm runtime jar file (50MB) and the Document management on the CRS has a limit of uploading only 20MB jar files. To get this working, I was wondering if UCCX has some way of setting classpath for such dependent jar files so that I can use them while scripting.
Any suggestions would be helpful!
DM
Edward Umansky Mon, 03/08/2010 - 18:52
  • Silver, 250 points or more
You should be able to split up the .jar file into smaller pieces, or remove the components you don't need. What jar file are you trying to load?
