cannot access eth1 at first time
Feb 10th, 2010
I am having problem to open the login page from eth1. In order to do that, I need to ping eth0 first then I am able to.
I put eth0 and eth1 in two different vlans.
eth0: 10.99.228.250/23
eth1: 10.99.232.250/23
As the routing table shown, I config gateway 10.99.232.1 for the first two subnets. I do not have this problem when my laptop is in these two subnet. But my question is if this is the correct way to do. If I config 10.99.232.1 as the gateway for all the ip subnets in my LAN, will it affect the comunication between the reporting devices and eth0? If MARS need to talk to the reporting devices, most likely it will go throught eth1 instead of eth0 if I specify 10.99.232.1 as the next hop for my LAN. Any one can help please?
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.19.238.0     10.99.232.1     255.255.254.0   UG    0      0        0 eth1
10.19.96.0      10.99.232.1     255.255.254.0   UG    0      0        0 eth1
10.99.228.0     *               255.255.254.0   U     0      0        0 eth0
10.99.232.0     *               255.255.254.0   U     0      0        0 eth1
169.254.0.0     *               255.255.0.0     U     0      0        0 eth1
default         10.99.228.1     0.0.0.0         UG    0      0        0 eth0
Cedar
nomair_83 Mon, 03/01/2010 - 13:28
  • Bronze, 100 points or more
I would suggest to use eth1 only for mars managment.
