Cisco Rouer 1841 problem on F0/0 and F0/1 no power
Answered Question
Feb 10th, 2010
Dear All,
I want to ask you that i have cisco Router 1841 but on port F0/0 and port F0/1 not have power when i plug cable to this port.
this is message that i got :
Router(config)#do sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.1.1     YES NVRAM  up                    down
FastEthernet0/1            192.168.2.1     YES NVRAM  up                    up
Router(config)#
*Feb 11 04:23:48.955: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Feb 11 04:23:48.959: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled Phy reset failed
Router(config-if)#Phy reset failed
what is going on ?
Best Regards,
Norung
Correct Answer by Leo Laohoo about 6 years 11 months ago
Hi Norung,
What do you mean "power"?  Both ports are not PoE.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Wed, 02/10/2010 - 20:38
Hi Norung,
rechard_hk Wed, 02/10/2010 - 20:49
Dear leolaohoo,
I mean that when we plug cable to Router then we see light on on port ( link,100 and FDX) but my problem is when i connect it i dont see the light.
Sorry i wrong to cleck correct answer.....
Leo Laohoo Wed, 02/10/2010 - 20:56
FastEthernet0/1 is OK but FastEthernet0/0 isn't.  Can you post the config?
