How to send a "carriage return" on Ciscoworks RME Netconfig Job ??
Answered Question
Feb 11th, 2010
I'd like to do a backup of the startup-config on the flash with the command copy startup flash:confg .
I created a job in the RME Job, but I can't send a "carriage return" to respond on the question: "Destination filename [confg]? " and the Job failed.
How to do that with RME Job ?
Any idea ?
Thanks for help.
Seb
Correct Answer by Dirk Woellhaf about 7 years 2 months ago
try a ""
I believe I made with this one.
regards
Dirk
Overall Rating: 5 (1 ratings)
Correct Answer
Dirk Woellhaf Thu, 02/11/2010 - 01:18
try a ""
regards
Dirk
s.perriard Thu, 02/11/2010 - 01:56
Hi Dirk,
Thanks !  it's work fine.
The right command is:  copy startup flash:confg
The need to be at the end of line, not under the "copy startup flash:confg" .
Thank you for your nice help.
Seb
