CME to CUCM as a H323 GW
Answered Question
Feb 11th, 2010
  • Bronze, 100 points or more
Hi All,
I have a small remote site that has a 2851 runnning CME 7 and wish to get the phones to register to a CUCM (v7.1)in London. Currently the PSTN connections are 5 x FXO ports that have PLAR OPX configured to reception x100. The CME will be registered as an H323 gateway as we are using analogue ports.
My question is how do I configure the FXO ports and dial peers to ring the reception dn once it is configured on CUCM? Can I use PLAR OPX and create a dial-peer with that pattern pointing to CUCM, or should I use translation patterns to amend the called number on the ports?
Any help and or example configs for the H323 GW would be appreciated.
Phil
Correct Answer by paolo bevilacqua about 7 years 2 months ago
Just plar to a number the CUCM can handle, and of course have DP covering it.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 02/11/2010 - 06:15
  • Hall of Fame,
    Founding Member
stowellp Thu, 02/11/2010 - 06:59
Just tested using PLAR and it worked that's great thanks, it's
much appreciated!
Cheers,
Phil
Related Content
