CiscoView Package for WS-C3750V2-48PS
Answered Question
Feb 11th, 2010
We've just installed the first (of many) WS-C3750V2-48PS switches in our network but CiscoView is not recognising the device.
Does anyone know which packages I need to install for these to be supported.
We're running LMS3.2, CiscoView 6.1.9, RME 4.3.1 & CS 3.3.0
Thanks.
Correct Answer by Joe Clarke about 6 years 11 months ago
You do not have the Cat3750 package installed properly.  You can try copying all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw to this directory (with Daemon Manager shutdown).  If the PSU repository is good, then you should be able to see your 3750s in CiscoView again.
Overall Rating: 5 (1 ratings)
BlueyVIII Fri, 02/12/2010 - 08:53
Hi Joe,
I did an SNMPWalk of the switch and the following was returned :-
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::catalyst37xxStack
Does this help?
Joe Clarke Fri, 02/12/2010 - 09:03
This switch is supported in version 9.0 of the Cat3750 CiscoView package.  You can update your packages from Common Services > Software Center > Device Update.
BlueyVIII Fri, 02/12/2010 - 09:54
Thanks for the reply Joe.
I did as you suggested (the previous 3750 package was v8.0), however, now whenever I try and use CiscoView for any 3750 I get the message shown in the attachment. (This included 3750's that used to work perfectly with CiscView)
Any idea's how I can fix this?
BlueyVIII Mon, 02/15/2010 - 02:29
I did an SNMP walk on a 3750-24-PS (that used to work fine with CiscoView) and it came back as below.
This means that both the 24PS and the V2-48PS have the same ObjectID. Could this be the reason they're not working??? (ie, this SysObjectID not included in the latest package version?
Any help?
Joe Clarke Mon, 02/15/2010 - 15:43
It sounds like the package was not installed properly.  How did you install the Cat3750 package?  Did you install the other supporting packages as well (i.e. DtShare)?
BlueyVIII Mon, 02/15/2010 - 15:49
Thanks Joe...
I only updated the Cat3750 package (from V8 to v9) by going to Common Services > Software Center > Device Update then using the Cisco.com, choosing CiscoView and then selecting the Cat 3750 package.
Is there anything else I needed to update?
Joe Clarke Mon, 02/15/2010 - 15:53
Yes.  You should always install ALL available updates.  If you do another device update for CiscoView, you will note that at least a new package, DtShare needs to be installed.  That package is required for Cat3750 version 9.0.
BlueyVIII Tue, 02/16/2010 - 02:06
Hi Joe,
I ran the Device Update again and this time installed All available packages, however, the problem is still occuring.
I've attached the list of packages that I updated and noticed that there isn't one called "dtshare" as you mentioned above (see attached screenshot). I installed all the packages anyway.
Once the installation had completed I ran another check for updates but there are now no updates available.
Any clues?
Joe Clarke Tue, 02/16/2010 - 10:47
I cannot reproduce.  Post your cv.log and NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
BlueyVIII Wed, 02/17/2010 - 05:38
Hi Joe,
Logs attached as requested. I last tried CiscoView at 13.28 on 17/2/10 and you can see from cv.log that appears to fail because of an unkown sysobjectID.
Does this help anymore?
Joe Clarke Wed, 02/17/2010 - 08:32
Post the list of files under NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs.
Correct Answer
Joe Clarke Wed, 02/17/2010 - 08:55
BlueyVIII Thu, 02/18/2010 - 07:15
Hi Joe,
I copied the Zip files as you suggested and everything is now working again. Both the old 3750's and V2's are now working perfectly within CiscoView.
Thanks for you help.
