AP541N/Guest access
steenbroberg
Hi Community
The datasheet for AP541, describe that it is possibe to make a welcome screen for the Guest access.
"The solution even lets you provide a welcome screen to greet visitors using your guest network (it could be a welcome screen or company policy"
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10492/data_sheet_c78-566239.html
Is there a build in Webserver in the AP541, witch make the welcome screen, or do AP541 redirect the client to a "external" webserver.
Can you provide me witvh a screen dump of the welcome screen.
alissitz
Level 4
Level 4
It allows you to reference an external server.  Here is the config guide, check pages starting on page 55:
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/AP541N/administration/guide/AP541Nadmin.pdf
This shows the config and how / where to enable this feature.
HTH,
Andrew Lissitz
Hi Andrew
I am also interested in setting up this feature.  Does it assume you have web pages already setup to handle a logon request from the wireless client, handle valid/invalid security details and then allow access to the public Internet when authenticated?  Are there no samples available that can be used to get things up and running much quicker?  If you have any further details on this it would be most appreciated.
Best Regards
Martin Townshend...
The http redirect will send the first time http request to a page off of a server that you have set up and or defined.
I do not have any examples of company websites that list an acceptable use policy.  You might try to google something to see what other companies have set up as an acceptable use policy.
HTH,
Andrew Lissitz
