Configuration with Configuration Assistant
Feb 11th, 2010
Hi, when I try to connect SA 520 with Cisco Configuration Assistant 2.2.(1) I have, after user/password, in Topology View:
unreachable unknown status
on SA 520 is enable CDP.
Steven DiStefano Thu, 02/11/2010 - 07:55
Hi Sal,
In the CCA topology view, you can 'Launch' to the Web GUI of the SA 500.  It is not "integrated" within CCA this release, other than topology discovery and launch point.   Right mouse click the SA500 (which will only show up if your CCA preferences are set to enable adjacent discovery and CDP is set) and DONT select add to community (wont work).  Instead there is a button called launch or something in there?
Can you try that and see if it opens a browser on your desktop and hits the SA GUI?
