02-11-2010 07:56 AM - edited 03-21-2019 02:09 AM
Hello. I have a question about using Netgear switches at a remote location.
The system will be a UC560 at the main office.
An SA520-K9 at the remote office and 5 SPA504G phones.
The remote office has Netgear switches (not sure of Model numbers) already.
Will these switches work to pass the voice traffic along with the data to the phones and PC's?
Please advise.
Thank you, Paul Santabarbara
Solved! Go to Solution.
02-11-2010 08:50 AM
The switches aren't supported, but might work. Cisco switches run CDP which allows the phone to learn about the voice and data vlans. What device are you going to use on the remote site to setup an IPSEC tunnel with?
02-11-2010 09:05 AM
Dear Sir;
No easy to answer without knowing whether the switch is CDP transparent and can apply QoS properly. This is not a supported configuration as we cannot ensure the right QoS is set to the voice. Strongly suggest to go for the ESW switch to ensure QoS.
Alberto
02-11-2010 08:50 AM
02-11-2010 08:56 AM
Steven, an SA520-K9 will be at the remote site.
5 SPA504G phones will be used.
Would a Cisco ESW0520-8P-K9 be a better choice to connect the 5 phones?
Thank you, Paul
02-11-2010 09:05 AM
Dear Sir;
Alberto
02-11-2010 09:25 AM
Alberto and Steven, thank you for your answers.
With a UC560 in the main office can I set up the remote office as thus?
Thank you, Paul
