Aironet 1130 web gui users
Answered Question
Feb 11th, 2010
Hi there
I would like to have two different users for the aironet 1130 cli and web access. At the moment there is userA with a given password. When I want to logon to the web gui I have to use userA with the enable secret password.
Now I want to create a userB with a password and privilege level 15. userA and userB should logon to the web gui with THEIR passwords and not the global enable secret password. If I configure ip http authentication aaa, the login popup shows always level_1 or view_access, where I can logon with both users. When I want to reconfigure something, it shows the login popup with level_15.
How can I configure, that it initialy shows the level_15 instead of level_1?
Thanks a lot in advance
Overall Rating: 0 (1 ratings)
irishboyabroad Thu, 02/11/2010 - 12:26
I think I have exactly the same issue as you. Ive also configured ip http authentication aaa and I now only get "level_1 or view_access" when browsing to the AP. I want to get access to the full configuration web menu but I can't figure out how to do so.
You mention "When I want to reconfigure something, it shows the login popup with level_15." How do you do this ?
Can you post your solution if you manage to figure it out ? I'll do likewise...
irishboyabroad Fri, 02/12/2010 - 08:57
Thanks Dominic but I dont think the link is applicable as its mentioning CLI based accessS
I'm using TACACS ( actually tac_plus ) and when I log in to the CLI I connect
with priviledge 15 as configured in TACACS
cisco-1130ag#sh user
    Line       User       Host(s)              Idle       Location
*  1 vty 0     admin      idle                 00:00:00
  Interface    User               Mode         Idle     Peer Address
cisco-1130ag#sh priv
Current privilege level is 15
group = admins {
        default service = permit
        service = exec {
        priv-lvl = 15
user = admin {
member = admins
        login = des xxxxxxxx
But with the same user via the http interface Im assigned to priviledge level 1.
cisco-1130ag#deb ip http auth
HTTP Server Authentication debugging is on
Feb 12 16:19:51.670: HTTP AAA picking up console Login-Authentication List name: default
Feb 12 16:19:51.671: HTTP AAA picking up console Exec-Authorization List name: default
Feb 12 16:19:51.700: HTTP: Priv level authorization success priv_level: 1
My question still stands. How do I get access to the full aironet web configuration interface when using TACACS ???
Thanks in advance to anyone who can answer my query.........
