controller and APs upgrade??
Feb 11th, 2010
I have a set of APs and I need to buy a controller for them. please see the specification below:
Product/Model Number: AIR-AP1232AG-E-K9
Top Assembly Serial Number: FCZ1032Z022
System Software Filename: c1200-k9w7-tar.123-8.JA2
System Software Version: 12.3(8)JA2
Bootloader Version: 12.3(2)JA4
I am planning to install the 4404 WLAN controller.
do I need to make any upgrade to the software used by the APs?
thank you.
hassine laribi
Leo Laohoo Thu, 02/11/2010 - 13:52
You need two things:
1.  You need to prepare the LWAP image to convert your autonomous AP (aAP) to light-weight AP (LWAP); and
2.  You need to use the Cisco Upgrade Tool to convert your aAP to LWAP.
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
LWAPP Upgrade Tool Troubleshoot Tips
Hope this helps.  May I request if you can rate my post if this is helpful?  Thank you very much.
