ASA Logging Traffic Outbound
Feb 11th, 2010
I need to be able to find an errant PC on an internal network that is sending RDP traffic outbound.
Has anyone any pointers on this ?
I need to log port 3389 from inside to outside.
Thank you.
S.
Collin Clark Thu, 02/11/2010 - 11:44
  • Purple, 4500 points or more
Create an ACL that will go on the inside interface.
access-list extended find_pc permit tcp any any eq 3389 log
access-list extended find_pc permit ip any any
access-group find_pc in interface inside
This will generate a log message when an RDP packet is sent to the outside. You can view the log with
show logging
Is this what you're looking for?
Diego Armando C... Thu, 02/11/2010 - 12:39
  • Bronze, 100 points or more
SOmething easier
Access-list CAPIN permit tcp host PC-IPADDRESS any eq 3389
Access-list CAPIN permit tcp any eq 3389 host PC-IPADDRESS
Capture CAP access-list CAPIN interface INSIDE
Then wait until the PC uses port 3389. and whenever you can do a SHOW CAPTURE CAP
Hope it helps
